I remain totally paralyzed in trying to repair my ailing
Series 1 XJ6. I have 420G intake and XJ6 Series 3 ignition.
As posted before, most recently in Saloons, my engine idles
perfectly, but loses power and coughs through the carbs on
acceleration or when encountering a slight grade (both
around 2000 RPM). I can’t drive the car except at 20 MPH on
flat ground. I discovered that I can get these symptoms by
revving against the torque converter. I had my wife do this
yesterday, and I observed the coughing for the first time.
It is truly awesome: fireballs out of all three carbs–each
impressive and all three about the same. A generous spit
from the hisser landed on the wing and burned for a second
or two.
As posted before, I’ve tried everything I can think of to
find out what’s wrong. The low power problem has come on
gradually, but one day reached the ‘‘backfire’’ stage with
extremely low power. The ignition advance is as Paul S.
specified–about 10 deg at idle and about 20 at 1500 RPM,
about 25 at 2000 (didn’t try to go higher).
The problem, however, is unaffected by radical changes in
ignition timing and unaffected by radical changes in
mixture. In other words, I can’t seem to get the problem
slightly better by changing these parameters.
Cam timing is spot on and has been since I’ve owned the car.
Fuel delivery is within specs. Compression is even and fair
(90,000 miles). Valve clearances in spec. I’ve swapped out
every ignition component, sequentially, with no effect.
Connecting the ignition directly to the battery had no
effect. I’ve done every conceivable vacuum leak check–but
all at idle speed.
Questions: Does the equal cough up among all three carbs
give a clue? Could it be a single intake valve? Any vacuum
leaks that occur only under load? Thanks!–
Bob Wilkinson, 73 XJ6
Saint Louis, MO, United States
//please trim quoted text to context only
