In reply to a message from Rob Reilly sent Thu 15 Sep 2016:
Rob,
Yes, I bumped into a couple of pics last night.
The tube is a neon tube, presumably to indicate if the coil is
putting out anything at all, but not enough to jump the gap (Same
thing as the old fashioned screwdrivers with a built in voltage
indicator). The neon may also be there as part of the electrical
circuit, rather than just a light bulb indicating ‘‘Igor, don’t
touch!’’.
I would say that the tester has to run at something near red line
frequencies. When a coil starts arcing internally the performance
initially degrades as revs (i.e. duty cycle) go up, until enough
carbon has been deposited, or the area is hot enough that it just
keeps sparking there, then the degradation also happens at idle.
The closed points heat test is also worth doing, although this
won’t test the condensor heat response, and ignores the ambient
heat change as a result of running an engine.
Earlier I was more inclined to just replace coil and condensor.
We have a known good set of points and condensor in the garage. It
only takes a few minutes to temporarily connect these two, if the
car runs better then we usually just replace both. Having a motor
tester to actually look at what is going on is a bit more
informative, but the symptoms and troubleshooting ususally give
ample clarity for a diagnosis. We use the same test coil/condensor
for everything from a 4 cyl to a 12 cyl.
Still haven’t decided if I want to make a test unit. I hear a lot
of ‘‘Lucas is crap, Bosch is better.’’ I suspect the truth is more
like ‘‘Old is Old, New is New.’’ but it would be nice to show the
difference visually.
Andrew–
Charles, Andrew, I found a few of those Snap-On coil
condenser testers on ebay, so I understand what you mean.
This one has a gap calibration printed on the case, so if it
jumps a 1/2’’ gap the coil is good and if it won’t jump a
1/8’’ gap it is no good. I imagine the box has some circuitry
that simulates a set of points opening and closing at a rate
of some hundreds of times per second. The heat test
simulates the points being closed for five minutes while the
coil heats up to operating temperature, then you do the
running test again. I can’t make out the little glass thing
under the screw points, is that a fuse or a resistor or a
1968 3.8S
Zurich, Switzerland
