Wise guys, I’m seeking counsel and advice from the
electrical wizards.
A few months ago my 45012 Lucas coil dated 4-51 decided to
misbehave. The car was running fine and suddenly began to
buck and then stalled about a mile from home. It seemed to
be still getting spark, but after an hour of frustration I
called my brother and we diagnosed coil failure. Burned my
arm rather badly on the water elbow getting the old coil
off. BTW let me say that putting the coil under the intake
manifold on early 120s was the stupidest thing Billy Heynes
ever did! My brother brought my box of spares which happened
to have an above-carb mounting bracket, I changed the coil
for a Lucas Sports Coil also dated '51, now mounted above
the carb, and got home.
On Sunday I went to the Chicago British Car Show and stopped
the car at the registration table. Two minutes later the car
won’t start; the Sports Coil above the carb suddenly quit.
Again it seemed to be sometimes getting spark. But now I
carry 2 spares. Changed it and got home ok.
Yesterday I tried all 7 coils in my stash, including 1 dated
1950 from my Mark V, and all 7 started the car and it ran
fine for a minute or two on each. Including the 2 that had
misbehaved. All 7 have a resistance of about 3 to 4 Ohms
across the CB/SW or +/- terminals.
So my questions are:
- What is the failure mode inside these things? Is it heat
related? - Can they be tested on the bench?
- Can they be repaired? I would really like to fix the
period correct coils that misbehaved. - Should the coil be mounted somewhere away from engine
heat, like the lower right hand wing valence or the scuttle? - Should there be a ballast resistor in the circuit? Or is
it internal to the coils?
Let the wisdom flow like a stream of milk and honey…–
XK120 FHC, Mark V saloon, XJ12L Series II, S-Type 3.0
