It was Marvin Moore’s photo (thanks again Marvin) of a 10 55 dated Lucas FL3
from his XK140 FHC, alongside an early FL5 that shows the difference in the
two - really highlights that there was a substantial change in the internals
of the two Flasher Units.
Marvin’s 10 55 dated FL3 photo is identical to a couple of excellent photos
I have found in period Lucas Catalogues and Brochures that are late 1953
dated (Oct by memory) which I presume to be first batch typical of preparing
the launch brochure, so probably expect this to be close to date Jaguar
started using the FL3 rather than the Tong Sol unit in the XK120, but will
need actual sightings of XK120s and date of unit to be more sure of this.
Fortunate that Lucas does date all there components, so will eventually
identify the FL3 > FL5 demarcation as well.
Beggers the question though - what exactly is the unmarked Flasher-Unit in
Mikes photo? I am guessing lack of markings indicates it was originally
marked/branded with black ink like the FL3 unit and nor of course stamped as
the usual FL5 unit. Maybe the very first FL5 units continued the black ink
marking, or maybe its another brand unit altogether.
Roger Payne - XK140MC OTS; E-Type 4.2 S.1 OTS; DSV8.
Canberra.
PS. An interesting aside but relevant to what was going on in UK at this
time is another period TRICO catalogue I have including a loose URGENT
recall sheet inside, advising that the catalogue detailed new design flasher
units/lamps are immediately withrawn from sale as last minute change to UK
legislation re wattage and visible surface area had made there new line
illegal. You wonder how much influence Lucas may have had in getting
legislation changed to suit, as this was all geraed up for the XK140 launch
with the new legal flashing indicators installed, and those who have read
the detail I have provided within XK140 EXPLORED will see that the very
first XK140s used a different front FLASHER Lamp Unit than the familiar
XK140/150/Mark 2 unit that was presumably not ready in time for the Oct 1954
launch of the XK140.
If this sort of detail is of interest - save these XK-Lovers postings - as
you wont see it published in a any of the XK books.-----Original Message-----
From: owner-xk@jag-lovers.org [mailto:owner-xk@jag-lovers.org] On Behalf Of
Mike Balch
Sent: Monday, 18 June 2012 10:20 PM
To: xk@jag-lovers.org
Subject: Re: [xk] Lucas FL3 Flasher
In reply to a message from Mike Balch sent Mon 18 Jun 2012:
Looks like I am wrong about this being a Lucas FL3 flasher. Roger
sent me his photo of an FL3 flasher next to an FL5 flasher. Not
sure what my flasher is, although I do believe it is the same
flasher that is on Tadek’s car. Must be an early but common
replacement flasher.
Mike Balch
'53 OTS
Des Moines, Iowa, United States
