George,
How about the possibility of a loose tappet guide. I know that usually only
happens with engines loaded up with emission controls. Easy to check.
Gene McGough
XK-150 FHC S834515DN
XJ6C II 1976----- Original Message -----
Sent: Saturday, February 05, 2011 3:43 PM
. . . Suddenly while driving at a
constant speed a hard metalic knock started that my scope places
between #4 and % in the center of the head.
The knock is not always in time with the engine speed–it will come
and go at steady throttle.
JCRC SE member JCNA Publications and Authenticity Desk
Columbia SC, United States
In reply to a message from Gene McGough sent Sat 5 Feb 2011:
Thanks Gene-it is a 150 but I did pull the cam coovers to check
valve spring strength and the cams–all is fine there.–
George
I posted a reply on the XK engine forum. Good luck.
Joel–
ex jag, '66 E-type S1 4.2, '56 XK140dhc, '97 XJ-6
Denison, TX, United States
