Hi everybody,
May-be somebody can help me with this:
S-810027 gets a new engine (G4568 8S) which is a C8610 block. Now I found
out that I need other front engine mounting brackets for this later block:
Does anybody has a pair of these brackets (C8783 and C8784) which they
would sell to me ? These part numbers are for later XK 140s (from engine
number G1908) and for all XK 150s.
Thanks in advance for your help!
Jaguargreetings from
Urs Haehnle
Evilard / Switzerland
In reply to a message from Urs Haehnle sent Tue 15 May 2007:
Urs
I know the early E-type engine brackets are still available from
the usuals. Since I have a Series I E-type and a XK140, I see if
the E bracket can be easily modified to fit the 140.
Joel–
ex jag, '66 E-type S1 4.2, '56 XK140dhc, '97 XJ-6
Denison, TX, United States
Hi Joel,
thanks in advance!
Urs----- Original Message -----
To: xk@jag-lovers.org
Sent: Tuesday, May 15, 2007 4:04 PM
Subject: Re: [xk] XK-140/150 Engine Mounting Brackets required
Urs
Joel
Urs,
Do you have a photo of the correct motor mounts you can post on the
forum or email me directly at getmws@Bellsouth.net? I have
numerous sets of motor mounts of indeterminant heritage and I also
have a spare 3.4L XK-150 motor. It is possible that it came with
its original mounts and they currently reside amongst the hoard.
Regards to all,–
Urs Haehnle
