Straight W30 non-detergent is the proper oil to use in the 150 transmission
and OD-----Original Message-----
To: XK Lovers xk@jag-lovers.org
Date: Monday, April 20, 1998 10:48 AM
Subject: [xk] XK 150 Transmission/Overdrive Lube Question!
It’s about time to change the gear lube in my '58 XK 150 FHC.
Question 1
What lube is recommended? Is Redline a suitable lube for an old Jag?
Does anyone have any suggestions?
Question 2
How much oil does the transmission/Overdrive hold?
Question3
Do the Tranny and OD drain from seperate plugs?
Question 4
Do they both get filled through the dipstick hole in the interior?
Question 5
I don’t have a manual for a XK 150. Is one available?
Thanks in advance for all the help. The XK Digest is a life saver!
Hi Mlarsen & all – DON’T EVER use “gear lube 80/90” – you’ll destroy the
gearbox/overdrive very shortly! The factory calls for a straight 30w oil
in both – use this if you don’t want problems. I hope this helps – Larry
Martz [USA, Calif.]**********
Someone told me that you can use gear lube 80/90???
Any thoughts???
Any thoughts???
No don’t use it. The hypoid additives in this oil will attack bronze
bushings in your transmition. Use only #30 non detergent oil. Castrol is
still making it. It is used in some older tractors check out farm supply
stores.
Bill
1955 XK140 ots http://www.nbcanoe.com
As I said earlier, use only a non-detergent straight 30 weight oil in the
150 transmission and OD unit. 80/90 wt is used in the later all-synchro
trannies like in the 65-67 e-types, etc.-----Original Message-----
To: xk@jag-lovers.orgxk@jag-lovers.org
Date: Monday, April 20, 1998 11:40 PM
Subject: Re: [xk] XK 150 Transmission/Overdrive Lube Question!
Any thoughts???
OIl that is used in motorcycles is formulated with high shear strength to
be used in the motorcycles gear box. This is a non-detergent type oil.
Most motorcycle shops carry 30Wt. oil of this type._____________________________________________________________________
You don’t need to buy Internet access to use free Internet e-mail.
Get completely free e-mail from Juno at http://www.juno.com
Or call Juno at (800) 654-JUNO [654-5866]
No, the specification is the same for transmissions without the OD unit.-----Original Message-----
Date: Wednesday, April 22, 1998 3:38 AM
does it make a difference if you dont have overdrive??
I definately agree with Larry, especially because it is an overdrive
transmission!
Volvos and many other American cars, new and old all used 30W in the O/D
transmissions.
