I am looking for the length of the battery interconnecting cable, PN C2833 on the XK120.
Would anyone have the original cable an could measure it?
Also, is the battery clamp nut just a regular nut or is it square?
Tadek
Tadek
Thanks Rob,
Getting it from US to Poland is a bit of a hassle, especially that I have a piece of braided cable and one original helmet connector (missing the negative one though)
I can see part of the cable in Urs’ Anatomy on page 168, I thought perhaps someone might have the actual cable and measure the length.
Tadek
do you want front of car to battery or battery to battery?
the battery clamp U section plate across fron of batteries the nut is a square piece of steel say 1/2 x 1/2 inch same as nuts inside captive nuts 1/4 unf ? and interesting wording on head of bolt was not waht was typical to rest of an xK120 have photos
Battery to battery Terry please.
Thanks for the info on the nuts.
Tadek
OK will check did check solenoid to first battery 107 inches
