I’m looking for information about the interior ‘tacking’ pieces used for the XK120 FHC interior. My car was stripped when I originally got it so I don’t have anything to go on.
I seen some old posts on the subject, including some useful photos but nothing in the last 5 years or so. I’m also missing the rear panels that the lights were fitted in.
I do have replacements for all the visible, veneered wood but non of the usual suppliers seem to do the tacking wood?
Hi Dave,
In the USA those opera light panels come with the interior kits supplied by the usual vendors, I would check with your local suppliers. Also all the tacking strips have been offered on eBay by at least one vendor, very reasonably.
My FHC had the original (mouse ridden and tattered) headliner so it provided a guide for my installer to match. He replaced all the tacking wood and used vynide on all the aluminum angles that butt up against the veneered wood that curls above each door. There has been quite a bit of discussion on this topic if you search further.
Dave,
Picture 1 shows all the pieces of plywood needed to tack or staple the headliner on (I believe 3/8 thick but I need to confirm that. I can mail you a paper pattern for all this if needed. Ignore the 2 bottom center right angled pieces, those go under the dash
Picture 2 shows everything installed on car prior to headliner installation. The red coloured pieces are made of angle aluminum covered with Rexine (I can provide exact dimensions but I’m not at my shop right now) You NEED to have those. 3 pieces per side
The picture also shows a metal piece (grey coloured) that you also need to have. I’m sure it could be duplicated, even approximately if yours are missing.This is not just flat sheet metal. From memory, it’s a more elaborate piece. Again I can supply a paper pattern to reproduce the right size and curvature and also detailed pictures of that piece
The lamps panels are just plywood pieces, nothing fancy about them. I have patterns for that too.
The lights incorporate a sheet metal backing plate, covered in headlining material (picture 3) screwed to the plywood panel. The lamp itself is attached at the bottom of the steel panel.
If you have any questions, please let me know. I’m here almost every day
The XK 140 FHC applies a similar system but most (all?) dimensions are different (as the XK 140 is much larger in the rear).
Same is valid for all the hardwood used around doors and rear quarter window.
Baloo,
The XK10 FHC plywood panels are different, following the change of design of the roof line. The metal receptacles and light units are the same.
Bernard
Bob K,
Did I understand you correctly that the sides are also different (120 vs 140 FHC), or that the 120 and 140 are the same on the sides (only rear window different)?
Thanks.
Bernard,
I know this post is a couple of years old, but I’m in the process of doing the fabrication on my interior and wondering if you’re still able to give me the patterns for the plywood pieces?
Thanks for your help
Jim
Hi Jim
Į will be able to supply you this pattern.
However, Į am in Europe for thé summer
,and will not return to Florida until Nov 6 so Į don’t have Access to thé car until then. Hope you Can wait. Regards
Bernard
Thanks Bernard,
Appreciate you answering my question. I expect that I’ll be doing the headliner before then, but if not, I’ll certainly touch base with you for the patterns. I did have another question about that area for anyone that might be able to help. I don’t have the aluminum angles that go between the wood and the body sheetmetal. I’m going to have to fabricate them, and wondering if any one can tell me the thickness of the metal as well as the dimensions of each of the legs?
Jim
I have my 120 naked (no interior) so might be able to measure those aluminum bits up for you. I’ll need a bit more info on which bits you are referring to.
I also have the original bit of cardboard out that fits at the rear window if you need dimensions on it as well.
Bernard
I wouldn’t mind a copy of the patterns for the wood bits when you return as well. There are a few bits of wood still in the car, but I fear others have gone walkies. November/December will likely work for me just fine. as I don’t see myself getting serious on the interior before then.
The items I’m referring to are the, I think aluminum, angle strip pieces that are attached to the wood headliner mounts. The angles are upholstered, and the only thing you see in the finished car is the narrow edge next to the wood door trim. It hides the edge of the wood headliner mount that you would see if those angles weren’t there. The shape is pretty easy to ascertain as it matches the shape of the door opening, I’m just trying to make sure about the gauge of the material and the dimensions of the angle legs. The larger side, which attaches to the wood, isn’t real critical as it’s hidden, but I’m mainly looking for the width of the narrow leg that you see in the finished car. I’m guessing that width is also controlled by the thickness of the headliner mount plywood, which, if you happen to have any of that handy, I’d appreciate knowing the thickness of it also. I think it’s 1/4", but I don’t have any, so am just guessing.
