On getting around today to installing the rear bumper spring bars it appears the pair that came with my basket case XK120 are for the coupes as there’s an inch gap between them and the side members.
OTS p/n C.3784
FHC & DHC p/n C.5807
The reach of the ones in hand is 3”, should be closer to 4” I expect.
Can anyone confirm this is part number C.5807?
Fixable with an inch of shims, but I’d rather install the right parts.
That slight “kink” in the bar, (where it attaches to the large chrome nut) is actually “damage” and , when straightened, will very likely correct the spacing you’re concerned about.
Let me know if you need a picture of a “straight” one.
Ah. Thanks for that observation, Dick. They’re both like that, so it would appear they were hit way back when, maybe backing up into a wall since there was no rear end damage. Looks like Mitch has provided the pic of a straight one … thanks, Mitch.
There’s a large, chrome extension that passes through the body. If I was to force the piece in place it would cause the extension to bear down hard on the aperture and sever the finishing grommet … so, shorter answer, no.
They sure look it. It’s been so long since I restored these parts I’ve forgotten what I did. I certainly would have “straightened” them, though obviously ignorant of the correct shape.
