My 1958 LHD XK150 DHC came without the clock or the trip reset cables and try as I might, I cannot see on any pics exactly how they mount to the under side of the dash. The best my research threw up was an old 2010 thread with pics that aren’t there anymore and a brief but inconclusive discussion.
So, please can anyone help with:-
Pics & lengths of the correct cables & fixings that I need to find (Trip & Clock).
Pics/description of the under dash position & mounting mechanism.
Pics of the cables in position under the dash.
I know that this will all turn out to be ridiculously simple and obvious but I need to be sure that I have got it right.
Andy,
There’s a panel that mounts under the dash. I don’t have mine handy, but here’s a picture of one for a MKII:
The ends of the two cables attach/mount to the holes on either of the steering column. Each is only about 8 inches long. Good luck finding a pair, they’ll be fairly expensive when you do.
Here’s a pic from my ‘59. The cable is treaded with a step. You insert it through the under dash panel and screw the bezel onto it. My car is an automatic but that shouldn’t make a difference.
Pat H
Thanks for your help with this - pics are always a big help.
I didn’t even know that there was an under dash panel and I have never seen a pic of one until now.
So it seems that the trip and clock resets are set back from the dash edge. Is the one in the pic a Tacho or clock reset? Presumably the other one is on the other side or are they both on the same side?
Yes, there are two located 3 inches back from the dash face. Obviously the one below the speedo adjusts the clock and the one below the tach adjusts the trip odometer. Three pictures attached.
Pat H
Thank you - that’s really kind of you to offer but I will probably end up sending it into a trim shop and taking their ready cut panel as part of the entire job. .I really appreciate the offer though and might even come back to you about it if I change my direction with the trim.
