Most of the shifts are so smooth they can barely be felt,
but the 1-2 shift, even under light throttle, is quite
dramatic, causing the car to seemingly leap forward. The car
shows only 22K km. Could something be stuck from sitting?
Thanks,
Jason Yardley–
JMY
In reply to a message from JMY sent Tue 30 Jun 2009:
There were several TSBs for fluid change and reconfiguring the TCM.
You might even need to delete/clear the transmission adaptations
with WDS (ver 30 or later) or IDS (any version).
The local dealer can scan your TCM and check to see if any software
upgrades are available.
bob gauff–
That is not normal. What year? XK8 or R? Check engine
light? Miles? Transmission service history?–
Tom Porter
Ellijay, GA, United States
