I have a 97 XK8. Love it. The brakes are very soft. When I try to
stop, push hard on the brakes, Not what I would like in stopping
power. I have replaced the front brake pads, thats all. For 4
years have not had to touch the brakes. The brake reservoir is full
for the last 4 years. I would think the brakes on a 97 jag would be
really solid. Anybody have any suggestions. I bought a new FORD
FOCUS… I like the car… when I push on the brakes, it feels
VERY solid… Would think a JAG, would do the same… Do I need
to change all the fluid?? OR what???–
kodpkd
Loveland, United States
Could be air in the brakes. Try to have them bleeded (and change the fluid
by the same token). Mine were the same after I painted the calipers and I
had a real time bleeding them, lol.
ciao,
skater-----Original Message-----
Sent: Thursday, February 17, 2011 9:47 PM
To: xk8@jag-lovers.org
Subject: [xk8] XK8 Brakes
kodpkd
In reply to a message from skater_R sent Fri 18 Feb 2011:
I am ready to change the brake fluid, and bleed the brakes… Once
again it is a 97 XK8. I do mast of my car maintance. Are there any
tricks in bleeding the brakes… Thanks Kevin–
kodpkd
In reply to a message from kodpkd sent Tue 22 Feb 2011:
Ok… I bought a quart of DOT 4 brake fluid… Bled the brakes…
My brakes are still VERY soft. Can’t slide the tires. I think the
XK8 should have better brakes. Other people with 97 XK8’s must
have the same problems… Maybe the XK8 just doesn’t have good
brakes…–
kodpkd
In reply to a message from WhiteXKR sent Thu 24 Feb 2011:
I was careful when I bled the brakes… I used a hose, and could
watch as the fluid was pumped out. I replaced both the rotors and
pads in the front. If the master cylinder was bad, wouldn’t the
peddle slowly push to the floor with pressure. Maybe I will buy
the pressure bleeder and try again…–
kodpkd
kodpkd
peddle slowly push to the floor with pressure. I will also check
the lines to the rotors…–
kodpkd
kodpkd
In reply to a message from kodpkd sent Thu 24 Feb 2011:
A pressure bleeder is a bit more foolproof.
When you bleed into a jar with a hose, it is essential that both
the hose remains immersed and the master cylinder does not go
empty, otherwise air will get in.–
WhiteXKR
