There are two brackets out of the firewall that holds the instrument panel. There is a large slot in each bracket. Regarding the instrument panel harness and the main harness, do both go through the slots or only one or neither?
Here is how I did it. 63 FHC
If you go here you’ll find the Factory Fit threads for the 3.8 and 4.2 cars.
If you scroll down you’ll find hundreds of pictures.
Note that the dash wiring is different depending on whether you have a LHD or RHD car.
