Had a busy day redoing half of my progress. I had to remove the layshaft to replace the dummy shaft with a .98" oak dowel as Bill suggested. Good call I think as I found a couple needles dislodged despite being as careful as I had been. The length of the shaft is 8". This is the orientation of the part stack. The flat side of the small inner rings sit against the landings in the center of the gear. These plus the next outward rings retain the needles.
The left bronze one is of course the configurable spacer available in several thicknesses. It, plus the needles are the only parts available new here. Allowable gap is .002-.004. Mine is .002.
Next it’s time to start assembling the synchro sleeves. I’m starting with the 3rd/4th as I’m still trying to workout what to do about the somewhat worn 1st gear stop. These are the parts. 1 shim on each spring gave me 58 pounds of separation force.
It is critical to follow the manual closely on this assembly. The inner synchro sleeve has two center hubs, a tall hub, and a short hub. The tall one must face forward towards 4th gear. The outer operating sleeve has two chamfered edges, large and small. The large chamfer also faces forward towards 4th gear.
The shallow shaved teeth on the operating sleeve line up with the through holes for the plungers. The manual is confusing because it talks about the two shallow teeth matching with the opposing plunger holes, but it fails to mention that one of those teeth is on top/front, and the second is on the bottom/rear of the part. They look like this.
Assembling these is intimidating but pretty simple with a little care. Definitely use a bag because the balls are going to want to sproingggg. I did the whole operation in a plastic bag, with a large hose clamp to compress the balls. NOTE here: tall center hub and large chamfered edge. This is the front of the assembly
Even with the clamp it’s not going to just pop together, but it’s stable and you can stick the whole thing, including bag in a bench vice with a large socket in the center, and it will push the clamp off and snap it all together easily.
Now test the release force using a bathroom scale. Use a thin block in the center so it can separate when you push, but just far enough to test it, without the whole thing coming apart again. I got 60 pounds pushing very slowly, but only 56 pushing fast. But it’s also totally dry. With some lubrication I think it will be perfect.
Now insert two balls and plungers in the inner sleeve and install on the main shaft. The shallow tooth on the front of the sleeve, pictured above, must line up with this forward horizontal divot on the main shaft.
Test quickly to ensure that with the synchro sleeve slid rearward against 3rd gear, that the gear can no longer spin. This means the synchro is able to positively engage against the cone. In operation the outer gear would continue traveling rearward, partially separating from the inner sleeve, and would smoothly engage with the small keystone shaped teeth on the gear. The larger helical teeth of course engage with the layshaft cluster.
Before assembling the springs and balls on the sleeves, it’s a good idea to simply slip the two sleeves together and slide them both onto the shaft. Push against 3rd gear, and try sliding the outer sleeve rearward to engage with the teeth in all possible orientations and ensure that the two parts slip together smoothly no matter their relative position.
They might have a bad burr or chip that causes the parts to be less than smooth when coming together. You may need to hunt for new parts or experiment with a tiny fie. Both 3rd gear and its mating sleeve here are replacements, as is 2nd gear.
