Hi All,
I had to recently remove my friends dashboard in order to adjust the choke light that was not turning off when the choke lever is pushed all the way in.
Now I need to reinstall the dash. Removing was somewhat easy, reinstall, so far, a nightmare…
Does anyone know if there are more flexible, longer vent tubes available? Or if extensions are available?
I am not able to reinstall the current, old vent tubes into the bottom of the dashboard. There is not enough room for my hands to connect the current tubes. My friends XKE has A/C, so cant work from the bottom as the A/C is blocking lower access. Newer, flexible tubes would most likely work good to solve this issue.
Thanks in advance for any suggestions.
Bob
