Sideshowbob
(Robert Moore 90 XJS V12 Convertible Marelli)
1
I put the 90 XJS away for the winter over a month ago but I had to do an unplanned move to access one of my snowmobiles.
The temp was -12c/10f and suprisingly it started right up and idled just like it does in summer temperatures. There is a block heater on our XJS but I did not have it plugged in. I have been using Liqui Moly10W60 full synthetic oil for a few years now and I think it helped it crank and start so easily.
I was thinking of taking mine out just to start ip and fill up the gas tank. I must admit I got lazy and it does not like to drive in the snow. I canāt believe that back in the good ole days we used to drive rear wheel drive cars all the time. I canāt help but think when I drive the XJ-S in snow and ice Iām taking my life in my own hands.
Decades ago (about 1983) I was doing aircraft accident investigations and our team was dispatched to Alaska in Oct. Snow was about waist deep except the roadways had been kept drivable clean. Packed down snow about 2 inches or do on a somewhat deserted roadway and we had a FWD rental car. Decided to see how well it could track. Our ādriverā could not get it to skid out or fishtail at the posted speed. Was probably about 35 mph.
I have driven and have ridden RWD in snow and ice in many states, Germany, and Korea. Got to admit I thought that FWD Chevy we had in Alaska that night was good to have in those conditions.
I wonder sometimes about the current trend to have all wheel driveā¦sounds like increased maintenance and repair.
First FWD car I tried in the snow was terrifying. Not only that, but I only drove that because my buddy couldnāt believe I was going faster with my RWD car and even enjoyed itā¦
I hate understeer. With RWD you just steer with the throttle and with good tyres you have grip. Limited slip helps but I donāt have that yet.
I have driven both RWD and FWD cars, tens of thousands of miles, in the snow, all my life. It is my considered opinion that FWD isnāt all that much better in snow than RWD. I havenāt had a snow tire mounted on a car for over 45 years.
If it gets bad enough to where I need that, I just stay home! My wifeās Subaru is AWD, with Michelin Defenders, and it never has an issue in all but the deepest of snows. 99% of the time, it does just fine.
I actually prefer FWD in the snow. I like how you simply steer the direction you want to go, and the front wheels pull you that way. The rear just comes along for the ride.
RWD is way too difficult with steering up front and power in the back.
I think a lot of this is what you grew up withā¦by the time i was driving in snow, almost all cars were FWD.
Well, I guess I grew up in the age of RWD. I still prefer it. I will trade RWD in the snow with oversteer to torque steer any day. As far as steering in the direction you want to go, what happens when that doesnāt work anymore and you get understeer? No way to pull out of that.
Winter tires really help too.
I do like AWD. I havenāt seen extra maintenance for it. AWD and antilock brakes with traction control are a different world from the '76 Olds Cutlass I learned to drive in.
I agree, RWD gives a lot more control, but ONLY if you know how to use it. Otherwise, itās too easy to swing the rear around. My XJS is first RWD car since my mid 20s. I am so bad at RWD that Iām even nervous driving in the rain. I should probably go find a huge wet parking lot and teach myself.
Once a year when there is snow i go to practice ina parking lot. I grew up with BMWs and Mercedes and feel much safer in them.
Greg with that XJS you have you should really do some drifting in the wet. Itās fun! And it really helps when it happens and youāre not prepared.
No, with FWD you suddenly go straight ahead completely out of control, and with RWD you can steer with the throttle and the front wheels can concentrate on the steering.
I had an Austin 1800 for many years and drove it year round. With RWD, the driver had control over front and rear. The steering wheel controlled the front and the gas peddle controlled the rear. With FWD, the only control was over the front wheels and when they let go, you were along for the ride. You did have to go a lot farther into stupid territory with FWD, but when you did loose traction there was nothing left and you had to ride it out.
I could not disagree more. My first car was an MG Midget. I could do square corners with it on snow and ice. Give the wheel a quarter turn, blip the throttle, get the rear end swinging, at 90 degrees, counter steer and give it gas: Result a 90 degree turn and accelerating straight ahead while throwing up rooster tails. My second car was an Austin 1800 and didnāt have the handling of the MG. When you got into trouble with it, you didnāt get out until you slid to a stop.
All RWD cars Iāve owned before were really one wheel drive. No limited slip.
With my XJS and limited slip diff, Iāve been enjoying the push of both wheels on dry pavement, instead of one tire spinning and one tire āparkedā.
I agree, will probably be very fun with limited slip?
On a tangent, Iāve also noticed since i switched from 90W to 140W oil in the diff, the limited slip is even better. Less tire Spinning/chirping and quicker traction.
Although first 15 minutes of driving its actually worse - guess the oil needs heating up?
