Hi guys,
It’s aeen a while, hopelfully you are all doing OK.
I reckoned you all might want to hear some tricks on
installing the 123-ignition system while the memory is
still fresh.
While the install/swap itself is relatively
straightforward, here are some noteworthy things:
a. The set-up instructions revolve (quite literally)
around cylinder #1, but, as is probably common knowledge,
timing of our beloved ones is set on #6 (the
foremost/frontal cylinder). Those 123-instructions,
especially dealing with connecting leads by cylinder
numbers, were therefore not a big help.
b. The key for me was to (eventually) get back to a few
basics: you need access to the timing mark; this should be
set at or near the 10 degree mark by rotating the engine;
the rotor arm revolves counter-clockwise; if the timing
mark comes up, the rotor arm should point to the #6 spark
plug lead; counter clock wise from this #6 lead the other
plug leads are numbered 2,4,1,5,3 (6). This is easy to
remember: 15 is too young, 36 too old, 24 just right (wish
I made that one up).
c. The 123-distributor takes some confincing to mate with
the drive - it turned out that there’s a slight machining
error on the 123-drive (my copy only?), that prevents it
to slot in one of the two possible positions - you have to
turn it 180 deg. to correct this. It is possibly that by
doing so, your timing is also 180 deg. off. If the setup
at b. reveals this, you can to this by re-placing the
leads (taking care of the mirror image you have to
create).
d. Another difficuly was to make the clamp to catch. It
turns out that the diameter of the 123 is slightly
different from the original 22D. You migth have to loosen
the vertical locknut of the clamp, reposition it by
inserting the 123, remove the 123 carefully and fasten the
locknut in the new position.
The result is BTW very promising - the engine runs
beautifully, but I didn’t test drive it yet.
Frans
'67 OTS Series 1, open head lights.–
Frans S. - '67 S1� OTS 4.2L Maserati 3200GTA
Amsterdam, Netherlands
