We have used it here on the island of Madeira.
It initially sounds great - no corrosion, and doesn’t boil until 200c or something like that.
We have found two issues in practice.
- It seems to find leaks like nothing else.
- it has a lower specific heat capacity than coolant.
While the problem with the first is obvious - on a new build, this seems fine, the second is not so obvious, so I will expand.
Specific Heat capacity is the amount of energy it takes to raise the temperature of a substance by 1 degree c.
Now, bear with me, I cannot remember the exact numbers - they are not hard to find if you want to see them, but plain water is something like 10 Joules of energy per degree per kilogram.
50/50 coolant is something like 8.6
Evans is something like 6
So, Evans will take onboard 40% less energy per kilogram than Water (for the same temperature rise.
If your cooling system has 20% spare cooling capacity, or you live in northern climbs, then this is fine.
If your cooling system is a bit touch and go, and it’s a warm climate, then the cooling system will run hotter.
But hey, that’s OK, because Evans doesn’t boil until 200c or something, right?
Correct, it doesn’t, but by the time it has boiled, you have already cooked your engine.
We have had an offroad racer ignoring his gauge, thinking that the evans coolant would save the day, but in reality, he overheated the motor and cooked the oil.
Evans is fine if you have this spare cooling capability, but we find that cars run hotter on it, because they dont have the spare capacity available to use the lower heat capacity fluid.
Note - this is also why adding water to an overheating car can sort the issue out for a while, the higher SHC of the fresh water improves the cooling efficiency.
On the island here, we dont need anti-freeze, we need anti-corrosion.
I’m still hunting for an anti-corrosion additive that is cheaper than normal coolant!
