I’m a long time (28yrs) XJ40 owner and forum user. My best friend is seriously thinking about buying an XJ-S Vin SAJTW5848LC166741. Unfortunately we live in Dallas Texas.
Is there anyone in the Tacoma WA area who would be willing to go and check the car out for a fee?
I really want to get my gear head friend into the Jaguar fold
Thanks so much and feel free to contact me on or off line.
Well we found a local jaguar mechanic who agreed to look the car over. So the broker who’s putting this deal together drives the car over to the mechanic … and …
… they couldn’t get the hood open !! One side just refused to release no matter how much they pushed and pulled. Crazy because they had it opened a few days before to send pictures.
Can you give me a little more information or point me to a source that may give me step by step directions on unbolting the hood from the front. Is it as simple as just removing the grill? We’re doing this long distance so any info would help.
Grooveman,
I removed and replaced the hood (bonnet) on my wife’s 1990 XJ-S convertible a couple of years ago when I restored the engine bay. From memory here is what I believe is necessary to loosen up your hood in your situation with one hood latch somehow stuck.
Remove the small Pozidrive screws (maybe 4 to six of them?) holding the front grill in place and lift the grill clear of the car.
With the grill removed you will now see four bolts (1/2" or possibly 9/16") that fasten the hood to the two hinges (two bolts on each side). Remove the bolts.
At this point the hood should be somewhat loose even though it is still being held in place by the two gas struts (one on each side towards the front of the car) and the stuck hood latch. It might be possible to release the stuck hood latch by having one person carefully lift and lower the hood at various points while someone else is simultaneously operating the hood latch release to the open and close positions. They need to be careful not to damage the paint around the edges of the hood and the corners of the car where the hood fits.
I have never had a stuck hood latch but if I did that is what I would try.
BTW, I have heard of hood latches getting stuck like this but only when someone has slammed the hood shut. Although a firm slam is perfectly acceptable when closing an XJ6 or XJ12 hood, the XJ-S hood should be gently lowered into place and then the latch lock/unlock handled pulled to lock the hood.
You should find out if anyone has slammed the hood shut and have the latches inspected as damage to them or the pins in the hood that they latch to them may have occurred. My guess is that someone slammed the hood and that is why it is stuck.
When I bought my 95 XJS the PO (a jag enthusiast and still owner of jags) schooled me to lower the bonnet by hand, and then gently push down by placing my hand on the bonnet just above location of latch until hearing it latch. Driver side and then pass side. Usually I use a micro fiber cloth between hand and paint.
Just a technique I have stuck with. Believe for pre-facelift the same can be used except once lowered them you have the release/lock mechanism to finish the closure.
At times, my car’s bonnet stuck shut. I used a small pry bar, cushioned by a shop towel at the trailing edge. A gentle nudge and it popped open. My car is an XJ, but the latches are similar, I think.
And decades ago, my 79 IHC Scout II did it. Same idea, forward opening. But, one latch only. similar to the Jaguar latches. Pin and pincers. Again a Bowden cable to the cabin. Flaw. Flimsy attachment of the handle to the cable. Prone to depart sans hood pop!!!
One way, with pull out, Whack the hood over the latch with the edge of a closed fist. Always worked…
