I think all XK and V12 caps are the same thread, none are bayonet. The size difference is illusory.
This is due to some having flat sealing faces with a washer (hole appears small) and others having a female taper in the cover (appearing larger) for an o-ring seal. The caps themselves interchange in terms of threads, as do the ‘bar’ caps…
I got mine from sng. It’s alloy vs chrome, (which I understand some are). One of the things I like is that I can add oil to a hot engine without having to unscrew the OEM cap when it’s hot)
Hi Joey…not sure i explained what i ment correctly. …most of these cap have an internal female thread…the cam cover also has an internal female thread…so u need an adaptor to join the two…does this adaptor come with the sng cap…Steve
I’ll get it
Report back as usual and give a fair observation
Looks neat, if in person it looks goofy I’ll tell you
There’s a gasket then a screw in ring then the cap
I’ll move the cap on every direction to see how it fits okay
It should be here in a week or so
There are others out there a tad lower but they have to be welded in
Hi Joey…sorry to repeat this again but just trying to ensure you get what you want…im assuming you have ordered C1022monza…this has a threaded ring inside…but you do need an adaptor to fit it to the cam cover…the SNG part number is C1022-B
I told Will to
Usually he isn’t as dumb as the rest of the people these days but yes…
Now it’s still 70 /30 the order comes in wrong, broken , stuck in customs and along with local mail and door package theft
I’m staying positive😀
Thank you my friend but your repeating
Like my wife locked up on the house with large bottles of wine…
Let’s see if this piece of kit even leaves the UK
Having fun…
Gtjoey1314
P.S. I’m getting the Monza cap , with the adapter screw in sleeve a kiss from Will at SNG and probably a dent in my bonnet😀
If you put clay on top of the Monza cap it should help prevent any dent if you lower the bonnet very carefully and then verify your clearance (if any).
Thanks John will do as per other John as well.
I seem to have alot of room, plus the angle but we shall see, Ill turn it in every direction to see if one side is closer.
gtjoey1314
I want to Thank MGCJAG, My buddy Will went on vacation, so I double checked my order…
Thanks again as I would have had just the cap AND NO GASKETS…
It never ends…
Ill take care of Will when he returns. gtjoey1314
