Hi All,
Chasing down a no-charge situation and have conflicting feelings about my diagnosis.
Backstory.
I just replaced the master cylinder and power steering belt. Everything went reasonably smoothly. On my test drive the car started to ‘feel’ odd and I notice the voltage gauge was reading very low. I turned off the AC and drove home. I shut the car off in the driveway and the battery was dead and would not turn over. I charged the battery and the car now starts and runs although it is not charging.
- Voltage gauge (in dash) reading +/- 12 V when ign on not running and engine running.
- Volts at battery 12.4 when running, same as not running.
- Ignition warning light never on. Not with the key at ign and not when running.
- Ignition warning light bulb has continuity (assume it works).
- Voltage across Ignition Warning Light terminals is +/- 7.5 V when key at Ign.
- Small brown ignition wire on Alt is 12V when ignition is on. 0V when ign off.
So my diagnosis is a dead alternator as I am not getting a charge and the warning light circuit seems intact.
My conflict arises from the lack of an Ignition warning light and the odd timing of just having completed some work.
The PO told me the Alternator is recent and it is one of the shinier pieces in the engine bay but I do not know any more than that.
Any thoughts?
Cheers,
Jordan
