As some on this list knows I sold my XJ-S a number of years ago due to my failing health. Subsequently I purchased a 2007 Aston Martin Vantage. Against all my precautions I was forced to replace the battery. I realize this is a Jaguar list but we all love cars and some might appreciate the massive effort involved.
For those interested I have documented the process in the link below.
Thanks Bernard - Good read!
ââŚsharp edges attract leatherâŚâ
I swear on some of these cars the engineers stand around reviewing the finished design, and someone says âExcellent work team. Now, how can we make it more complicated?â
While I sympathize with your desire to take it to the dealer, I seriously doubt they would take the care you did on the job.
the best of English engineering, makes one wonder?
Kirbert
7
Wow. Well, scratch AM off my dream list.
I probably would have just sawed those two sliding brackets into four pieces. Or just thrown them away; you already have a strap securing the battery, why do you need the brackets?
One thingâs for sure: I would IMMEDIATELY add a charging post to the exterior of the car, probably underneath the front end somewhere.
Porsche has some bad cars too where you canât get to the battery without power, and you work around that using some fuse in what could be the b pillar to power the car externally⌠but this bad? Count me out. Iâd have sawed the entire car in two.
Good job well done though.
It seems to me that some cars are designed specifically assuming that the ownerâs never work on their cars themselves but that they only bring it to the dealership or they have âtheir peopleâ to take care of it.
It also seems to me that over the years more cars are being designed that way. That is not to say that working on my four Jaguars isnât a challenge sometimes, but those challenges are usually something that a DIY hobbyist like me can reasonably handle with occassional help of Jag-lovers.
Nice writeup. Brings back fond memories as I also have a 2007 Vantage and had to replace the battery a couple of years ago. I used a Interstate AGM battery so the vent was not required. The car also had the original battery which lasted 10 years. The new one was an exact fit and as such, the sliding brackets did not need to be removed but just slid to the side as designed. Looks like yours had already been replaced in the past. I also modified the fiber panel but just used some snips. As it is hidden and does not show, I am the only one that knows. The positive box in the engine compartment is heavy cable to the positive of the car. Ground anywhere solid metal is and with a jumper box, you can work your windows or even start the car. I donât recall the job taking more than an hour. The V12 Vanquish (early 2000 range) is a real bear to change the battery. But as a degree of difficulty, try installing a fan shroud on a MK2 Jaguar. This now holds the record of PITA jobs in my book.
Dick, I didnât know you were in the club?
We are having the 50 AMOC at Limerock in June, you coming!
GTJOEY1314
The Vantage is a BULLET PROOF car that you can enjoy for 250,000 miles and beyond
Hi Joey, not in AMOC as there is nothing going on in the SE area. We have tried to get a few things going but without success. I have 3 customers with Aston Martins and only one is the club type. I will check out the 50 AMOC. I did not know about it.
I agree, Its a quiet group .
The 50th at limerock we are looking at 125 cars for a 4 day event .
Take a peekabooâŚâŚ
It is really the only event in the states for the entire year.
Other than a couple of BBQâs in my back yard. gtjoey1314
Iâm bringing thisâŚ
Kirbert
18
Upon closer inspection of the photos, I see both your old battery and your new battery have built-in handles for easy lifting!
Kirbert
19
The one thing I wish had been included in that writeup was a photo of the battery tray with the battery removed. I canât help but think weâre missing something. Are you sure the clamps werenât supposed to be slid off to the right? Thereâs evidently a panel there, but can it be removed? Or is the presumption that loosening the setscrews is supposed to allow the clamps to rock far enough to lift the battery out without sliding them at all?
The battery is flush up against an interior body structure on the rift side. The clamps have to some off by sliding them to the left. Some have left the clamps off in disgust. As you noted there is a perfectly adequate strap the holds the battery.
