Thanks for your views, Dennis.
It would be great if you had the opportunity to provide the measurements of the special wrench you made for the pump bolt removal. Then I could make such a tool before starting the project.
For the actual shaft seal replacement I have found these instructions:
*Bryan’s description in another thread:
If you attack it from the other end, once you’ve removed the cover,
the spring, the end plates and the rotor and stator (all very easy
on the kithen table!) you can remove a circlip and withdraw the
shaft c/w drive dog forward to gain access to the seal.
Providing you remember which way around everything goes back
together, that method is very easy and you don’t need to go
searching for a machine shop or someone with the Jag special
removal / re-fit tools to handle the drive dog. An added benefit,
you don’t need to worry about the drive dog being re-fitted in the
precise location on the shaft to avoid mashing up the drive
mechanism in the timing cover (as happened to one of our bretheren
in the distant past)
I think it only fair to warn them that correct re-assembly of
the innards of the pump is only really ‘easy’ providing you pay
absolutely critical attention to the orientation of the parts when
you remove them from the pump body. There are only two ways you can
install the rotors, stators and end plates.
*I have also found these instructions:
Step 1: If the power steering pump is operating correctly, the leak is likely due to a worn or defective shaft seal. This specific part (or a seal kit) is readily available from large auto parts supply chains for a very low price as this is a GM part. With the part in hand, compare it with the existing seal and continue with the following steps if they are identical. (I have already acquired the seal kit).
Step 2: Drill a small (1/8") hole in the metal top of the seal to allow access for a seal puller or small screwdriver. Be very careful not to touch the pump shaft … best to tape the shaft as a means to protect it during seal removal.
Step 3: Using a seal puller or screwdriver, grasp the seal through the hole and lever the seal out of its housing. Once the puller engages the seal, it will pull out of the housing easily.
Step 4: Thoroughly clean the pump shaft and the seal recess areas. Cleanliness is very important when installing the new seal. Inspect the pump shaft seal area for damage or wear. A slight scoring from the old seal will likely be visible and will not cause any problems when the new seal is installed. However, if you can feel any groove in the shaft from the seal, purchase a rebuilt pump assembly.
Step 5: Lubricate the shaft with a small amount of power steering fluid or silicone o-ring grease. Carefully locate the seal on the shaft and move it into position over the seal housing.
Step 6: Using a small hammer / block of wood or large deep well socket the same outer diameter of the seal, carefully tap the seal into place within its housing. The top of the seal should be slightly recessed (1 mm) below or flush with the top of the seal housing when properly seated.
