So I have a 75 XJ12C and a 90 XJ12 that’s making its way from Canada to Texas. I want to swap in a 5 speed manual in one of these cars but I don’t want to spend $5-7k on a kit. I’m in the US where T5 transmissions should be readily available used.
Mustang V8 GT T5, 2.95:1 1st. Replace rear housing with one from a S10 Chev T5 to move shifter to “right” position. Rebuild trans, adding cluster reinforcing plate available on eBay for about $75…
For an idea or two. Go to You tube. Johnathan Winans. Two truck operator by trade. Fabricator from junk as a past time. Adapted 5 speeds t two old engines. Buick Straight 8. Cadillac flat head V8. Principles seem to be transferable /
Somewhere , on J-L, I think, I read that the auto pedal box could be drilled for the added pedal !!1
Thanks, pedal boxes etc are not a problem as they are available. I just don’t want to drop $3500 on a new TKO trans when there are used T5’s available everywhere
I don’t know about the XJS so much but Brown’s Lane didn’t do sedans/coupes with a manual in LHD because there was no room for the pedal box. I briefly drove a manual XJS 6 here and it was pretty tight with the extra pedal even in RHD. Are there successful conversions over there?
I didn’t know that. Thanks for the correction. I read a history of Jags in the U. S. years ago that mentioned no manual XJays but obviously I misremember the text.
Wow, never new that you made a flywheel to adapt onto the flex plate, Awesome
Not to divert from the thread Norman but, are you aware of any such clutch pedal box that can be fitted to the 94 XJ81 which would include a master cylinder to can hook up to the ABS brake lines?
