Anybody knows if i can find a front screen panel to buy or i will have to make it by myself from metal sheets?
Finding out where the spot welds are and from where to cut the roof panel to replace
welding spot for the rocker too. Now i just need to wait for the bits to remove the welding spots. Going slow guys ,but going😁Doing small things when i have time. Also i don’t have yet a big metal sheet for the side panels so i have to do something else until it will arrive.
Not from the factory, but probably just how the water sat in various areas. Just a word of caution, try to work on one area at a time if you are cutting steel out. That will give you a better chance of the body staying straight(ish)
I was thinking a lot about this in the last days. I am also thinking if it will have distorsion. I will try to see if is possible to leave that corner for another time,and fix first the rocker and floor.
Not sure if is because the water didn’t get there. It looks like stainless steel. But when i will open there i willpost pictures. Thank you for your advice
Looking on the SNG site it appears they only list the one sill, just send them an email to confirm, they are a special order anyway so you want to be certain that it would fit both sides.
I will need the help of everybody here. I have a rear corner where i have doubts about cutting and welding.
https://youtu.be/u_IBGor6Ilk
https://youtu.be/jBdwq8XrVwI
Almost sure that my plan is not the right one,so i am asking advices before i mess it up. Thanks
Hi Andrei, you really need to look at bracing the car so that it isn’t trying to fold up on itself any further.
Your are a very brave man!
Thank you Robin. I will try to do that. Anybody that have done the body work and can advice me from where should i start to cut and replace by pieces?
You have to do. The years were structurally different. Panel from the new body will not be 100% compatible with the old body.
Both of them 92’ one from january,another august. The one that i will be welding have a bit of rust on the surface. Beside brushing and cleaning the rust,what else should i do to make sure that will not advance? I will try to see if i can make that vent boxes😐. Thank you for the answear.
