Can you explain the water flow. It looks like you are returning from the back of the heads. I guess it is too early to know whether you have even temperature distribution across the cylinders.
It will be fascinating to see if you can crack the original 500bhp with some more modern thinking.
Mark - I expect there to be dramatically better cooling - time will tell!
We carried out a trial installation in a S3 E-Type today. Fits like a glove! Could almost have been made for this conversion. Seriously - fits so well with seemingly more space than with the standard installation. No bodywork mods needed. Perhaps a case of “what should have been?”.
Perhaps a new lease of life for those unloved 2+2s?
Dunno … I’ll weight them one day. My heads are lighter that the equivalent XK 6-cyl heads and a little heavier than the SOHC heads. Block is the same as the SOHC block of course.
Must be some weight savings by deleting the 4 carbs and manifolds.
Amazingly good looking engine. I want one, but also know that won’t happen.
Kirbert
33
The thing I’d like to know is if anyone ever figured out why the original XJ13 crashed and how to update the design to eliminate that instability. That would make the notion of building a replica far more appealing.
Yes - it is pretty well documented now that the crash was likely caused by a rear tyre plugged to cure a slow leak.
No “instability” - and I speak as someone who has pored over each and every test report.
The car, even undeveloped, was stable and confidence-inspiring enough for David Hobbs to have set a UK lap record at MIRA of 161 mph. A record that was to stand for 32 years when it was broken by the McLaren F1 road car.
The basic design also survived Norman’s unintended “crash test”. Essentially only a re-skin was needed. The basic monocoque/chassis survived intact.
That’s astonishing - Jaguar was that penurious to patch a leaky tire being used for high-speed testing? Maybe standards were different back then, but I would never depend on a patch for a tire that would be operated at triple-digit speeds for more than a few minutes (and that’s on the street driving straight-line, not hard track duty.)
