I recently built myself an electronic wheel balancer. In the process, I spent countless hours testing, balancing, driving, and re-testing a pile of wheels and tires. To say it was an educational process would be an understatement. But here is what I have concluded:
First, Rudge-Whitworth wheels do a pretty crappy job of centering the wheel on the hub. The “cones” on Rudge-Whitworth wheels are ANYTHING but conical, and the final wheel positioning is essentially random,
The biggest take-away was finally having the means to prove something I’ve suspected for a long time. Namely, that balancing, at least on these cars, is INCREDIBLY non-critical. I’m sure we’re all used to watching modern high-speed wheel balancers come up with weight recommendations down to 1/4 oz. HA! 1/4 oz. is NOISE. Virtually meaningless in terms of measurability, and completely meaningless in terms of “ride quality”.
To prove this point, I balanced all four wheels on my car using my balancer. I then went for a drive, and found it is as smooth as it has ever been (and a lot smoother than I have ever been able to get it before with the current tires). I then added a one ounce weight to the left front wheel, and again went for a drive. NOTHING! Absolutely no detectable vibration whatsoever, at any speed. So I added another one ounce weight, right next to the first one. This produced a BARELY detectable vibration - so slight, few people would ever notice it. I suspect a third ounce would have produced easily detectible vibration, but didn’t bother to take it that far, since my suspicion was proven.
Combine the poor repeatibility of wheel positioning, and the above noted near-total insensitivity to balance, and even talking about balancing down to 1/4 ounce is pure magical thinking. It really cannot be done, and wouldn’t make ANY perceptible difference whatever if it could.
To me, that is actually all good news, because this new balancer makes balancing my wheels very quick and easy, with little skill involved. On all of my wheels, I spent much more time removing the adhesive left-over from the old weights than I did balancing and applying the new weights. And I should be able to commit the balancing procedure to software running on the balancer that will guide the user, step-by-step, through the process, making it nearly idiot-proof.
Ray L.
