Just to close this thread (sort of), I followed all these instructions
and it worked perfectly. The only thing I would add was that it was a
two person job while putting it back in, as I was in such constricted
space underneath I needed someone to pull on the starter from above
with a rope to get it up in to place.
Now the only issue is, the starter runs, but the car doesn’t start.
So, now I’m looking into that.
William G Higgins
1973 series 1 XJ6 4.2l
Vancouver, BC2009/12/22 Doug Dwyer dougdwyer1@comcast.net:
Keep at it.
Even though it’s a slight interference fit, if the mounting shoulder is
clean and free of burrs, and perhaps a bit of grease added, you should be
able to rotate the starter a bit to get a perfect alignment with the bolt
holes.
And, if the starter isn’t fully and squarely seated you’ll never get the
bolts started.
I find taking a break and returning to the task a bit later usually solves
the problem
Doug Dwyer
Longview Washington USA
1995 XJR
Alright, all of these instructions were great, thanks again Carl for
the clarifications with regards to bench testing. I just have one
more problem. Getting the starter back in the car. I’ve gone
underneath, hooked up a rope to help raise it into position, and now
have a drill bit as a guide so that I know that at least one hole is
lined up, but I can’t get the screws to fasten as I am fastening blind
into the other hole. Is there a trick anyone has, or is it just sort
of keep-at-it, and/or remove other engine parts sort of problem?
Jag-lovers Forums - Jag-lovers.
William G. Higgins
1973 Series 1 XJ6 4.2l
Vancouver, BC
