At 20:15 1999-12-17 -0600, Graham Murray, MCSE wrote:
1984 XJS H.E.
My car has a Trip Computer.
Congrats. If you’re really lucky, it might even work.
Can anyone tell me how it works, i.e. what do all the numbers mean, and how
do I reset the trip meter and clock?
Hold down the RESET button on the far right for several seconds, and all
figures will be reset.
To set the clock (running from memory, rather than doing it at the moment),
you’d hold down the HRS (hours) button and press and release the RESET
button (hold it down long enough to change the value, then release it - if
you hold the RESET button down too long, it’ll RESET the other
values). Same for MIN (minutes). There is no AM/PM indicator - the clock
runs a simple 12 hour cycle.
Miles/Km switch, if present switches the values between US and
Metric. Unless you have a UK model, in which case you may have Imperial
gallons. I only use mine (for what it is worth) in US mode (as the pumps
here display gallons and my odometer is miles), so the secondary units
mentioned below may be incorrect - they’re assumptions on my part:
FUEL shows amount of fuel (as metred by the ECU) consumed. Gallons or
Litres. If yours is accurrate (this seems to be the only thing truly
working on mine), this is useful for jotting down in your logbook between
fillups and noting the actual mileage from the odometer tripmetre.
INST displays instantanious economy (MPG or KM/L (I think)). The figure
may vary erratically, which is not unusual. Will usually be very low for
the first few minutes of driving (5-8 MPG), and as the engine warms up,
it’ll show a much healthier value (as much as you’re going to get with a
thirsty kitty). Go downhill, and the value will climb (because you’re not
using as much petrol). Can sometimes display ‘99’ briefly. Updates every
3-5 seconds or thereabouts.
AVE displays the running average economy. Same units as INST, but these
are average since the last RESET, and reflect economy of total distance
over total petrol used.
DIST displays distance (miles or km). If all is well, this should very
nearly be the same as your odometer tripmetre (if you reset them both at
fillups as I do). If not, then the other trip computer computations will
be inaccurrate.
AV SPEED reports the average speed. AFAIK, this is averaged over the
entire time the ignition is on, and therefore, if you spend a lot of time
idling while chatting to someone, the value will be lower.
TIME shows the clock. What a surprise.
DISP turns the display on/off. Well, at least OFF - pressing any of the
other buttons (like FUEL) will turn the display on and display that value.
RESET resets the logged values.
The trip computer has no battery backup, so if the automobile battery is
disconnected, the values will be lost. If you disconnect the battery, you
should probably RESET the unit with the RESET button just to ensure that it
is properly reset.
If you’re interested in tinkering, or an upgrade, you might want to swing
by my Trip Computer project page:
<http://jaguar.professional.org/TripComputer/tc.html>
I havent begun the project yet, but the basic idea is to replace the unit
with a more visually appealing one, but also one which can optionally be
used to interface to a number of projects people have discussed in these
forums.
— http://jaguar.professional.org/
Sean Straw '88 Jaguar XJSC 5.3L V12 (LHD)
Marin County, California '69 Buick GranSport 455 V8
