Xj12 ECU 16cu Advice Needed
Hi, new the the forum and already looking for advice. I have a 1990 series 3 xj V12 with Lucas ignition and a 16 cu.
Because I’m a sadist I bought the car as a non runner.
After speaking to the previous owner who inherited the car from his father, the car was fine but hardly used, tried to start it one day and it wouldn’t fire up. The car has since sat unused until I bought it…
Once I had the car home I checked over a few things and tried to eliminate the obvious. Drained the fuel tanks and added fresh fuel. New plugs, distributor cap, h.t. leads and while the air con pump was off changed the belts too. Car turns over freely and has a spark. Not tested the plugs out but have a tool to check the leads while cranking the engine. Figured as there was a spark I’d turn my attention to fuel. The injectors click when the ignition is turned on but the fuel pump was not running. Looking through previous posts found if I remove the orange wire on the pump relay, ground the relay the pump will run. There is power to the ecu and the fuel pump works.
Turning my attention to the ecu. I removed it and opened it up to have a look. Found a burned out resistor?
I’ve found a company here in the UK, AJ6 engineering who sell refurbished ecu’s but they’re not cheap to replace. Not being very well versed in circuits or electrics in general my question is, can this be repaired by merely replacing the burned out component? I’d like to know what could have caused this to prevent it happening again or is this a common fault and just age related.
Phil
That is a transistor; if you can read the numbers you may be able to cross reference to an available replacement part. My experience has not been great on availability or repair. Problem is that most are obsolete and they generally do not fail on their own; there may be another component such as a diode or capacitor that has shorted or gone open circuit to cause the transistor to burn out.
That said, only a few quid to try to fix. If it doesn’t work, AJ6 is a sure thing. eBay also, if you like to roll dice.
Does it run with the fuel pump relay triggered by grounding?
Hi Robert, thank you for the reply. Unfortunately the car didn’t fire up when bypassing the relay to run the pump. I’ll probably have to bite the bullet and buy a replacement ecu in case it has fried anything else
Untitled
I blew up the pic and it looks like a TIP31C, a ton on ebay and probably electronic component sellers as well.
Hi Kim, do you know if all tip31 transistors the same? New territory for me but if its a simple replacement for the sake of a few £ it could be worth a shot. It’s broken anyway so there’s nothing to loose. I emailed aj6 engineering but I haven’t had a reply. Here’s another pic of the transistor. I tried to clean it up a little and this is the clearest pic I can get of i
Nothing to loose indeed.
Examine the board very closely though to see if there are signs of other failed components that might not be as obvious.
If you find any electrolytic capacitors that are bloated or wet they would need to be changed as well.
Keep us posted.
No update as such but in leue of being able to repair my ecu I have the opportunity to buy a replacement. My ecu is a 16cu unit with the part number DAC6335 the one I’ve been offered is also a 16cu unit but with the part number DAC4119 from an earlier model. Are these units interchangeable?
DAC4119 is intended for Lucas ignition cars WITHOUT Catalytic converters.
DAC6335 is for a Lucas ignition car WITH Catalytic converters.
The car will physically run with the offered ECU BUT if you have cats, it may (guessing) run richer (more power) and cause them to not last as long? IDK for sure. Roger Bywater could tell you for sure.
I know some ECUs did not have an O2 sensor board (from the early non-cat 6CU line) so… I’m not sure if the non-cat 16CU supports O2 sensors, but I suspect it does … at least thats the way I’ve drawn diagrams for them.
~Paul K.
Thanks Paul. I have contacted Roger but unfortunately he isn’t online often… I’m sure he’ll get back to me once he can
Philip,
You can fit a non Catalytic ECU but it will hurt your consumption as it will have no oxygen sensors input.
Any earlier 16CU will work as long as the compression ratios are the same.
V12 ECU 16CU
DAC4118 16CU 1985 HE CEI 11.5:1 O2 Sensors
DAC4119 16CU 1985 HE CEI 11.5:1 NO
DAC4478 16CU 1985 HE CEI 12.5:1 NO
DAC4585 16CU 1986 HE CEI 11.5:1 O2 Sensors
DAC4586 16CU 1986 HE CEI 12.5:1 NO
DAC6335 16CU 1989 HE CEI 11.5:1 O2 Sensors
DAC6336 16CU 1989 HE CEI 12.5:1 NO
DAC6337 16CU 1989 HE Marelli 11.5:1 O2 Sensors
DAC6338 16CU 1989 HE Marelli 11.5:1 NO
To elaborate on Paul’s sage input, Phil; with catalytic converters a Lambda system was added to the ECU, incorporating an O2 sensor. This is mainly to protect the cats from petrol - the Lambda minimizes fat running…
While the engine, properly set up, will run perfectly without the Lambda added - as it would if the O2 sensor is disconnected.
I’m not sure whether the different ECUs are plug and play - ie that Jaguar kept the original wiring to the ECU. That would be Jaguars way of doing things, but the various injection systems may not be directly compatible, and the HE engine may have different fueling requirements - as may markets. Hence the need for different ECUs…?
Frank
xj6 85 Sov Europe (UK/NZ)
Recent similar discussion here:
I have a feedback ECU (4118 as I recall) but no cats and no O2 sensors. The engine runs very nicely
DD
Any chance you can get a better shot of that transistor mabye cleaned up with a cotton swab w/ some alcohohl on it? Usually the datasheet for a particular transistor can be tracked down and there are usually plent of substitutes, but I can’t read the first number very well and my guesses don’t come up with any direct matches.
The upper one BC558 is still avaialbe from Digikey and I suspect other vendors.
~Paul K.
Hi Paul, these are the best pics I can get of the T the transistor
Thanks for the pictures. I thought I’d be able to ID them but no luck so far running several searches:
Ti944
T1944
TL1944
TIPK31 which probably stands for Texas Instruments Power K31 BPJ transistor.
There is a series of TIP31x transistors with various max voltage tolerances, but K31? Still looking.
Generally you find an exact nomenclature match. A lot of the time a generic substitute transistor will work, but sometimes some of the characteristics need to be matched (switching speed etc).
Thanks for the pics, maybe they’ll be useful one day in the archives.
~Paul K.
Hi, here’s an update re my Xj12. Firstly I’d like to thank everyone who took the time to offer their advice, it’s appreciated. I’m pleased to report the car now runs…rough. My friend took the ecu and searched for a replacement transistor. He said the one he tracked down may not be the correct one but it was worth a try. While he was repairing the ecu I bought one from ebay and had it shipped over from the USA. I tried the repaired one first as a fail safe and after some effort the car fired up. It didn’t run for long and I still had to ground the ecu to motivate the fuel pump. But it ran. Turning my attention to the fuel rail as the car was over fueling. I found a faulty fuel pressure regulator which has now been replaced. The coolant temperature sensor is also faulty which I have bypassed to test the car. I have one on order but using the ecu from the States I can now start the car. Unfortunately I can only start the car with the throttle in wop and need to hold the revs up a little or the car won’t idle. In spite of this the car revs freely. As I work away most weeks I don’t have a great deal of spare time to spend on my cars hence it taking so long for an update. Happy with my slow progress, I’ll continue my fight to get it as it should be and update as I go. Phil
How did you ‘bypass’ the CTS, Phil?
The CTS is absolutely essential for correct fuel mixture - which relies on its correct resistance relevant to engine temp. Unless this resistance is correct there is no way the engine will start and run as it should. It’s not even worth while trying until remedied…
A couple of asides; all ECUs are not created equal - and focusing exclusively on one item may be counterproductive.
What is the test result of you CTS - resistance versus temps?
Frank
As Frank says, before reaching to any conclusion you should have a working CTS.
Bosch sensors are well documented, but they are all going to follow the same pattern of having a very high (e.g. 5k-10k ohms) resistance at 0’c and low resistance (~150-200ohms) at 80’c so you can either pull the sensor plug to mimic very low temperature or temporarily replace it with a resistor.
Pulling the plug out is one way to force a heatsoaked car to start. If underbonnet temperatures are sky high and ought not to be, a fuel injected car will never start because it can never inject enough fuel to provide a combustible mix. (The sensor erroneously reads a high temperature.) Pulling the coolant sensor forces it to push more petrol in and so long as it runs for just ten-twenty seconds, however roughly, that’s usually enough to force enough coolant to circulate to make the sensor start reading a more sensible figure and turn the car into a runner. I have started an unstartable car this way.
kind regards
Marek
Hi, there was no reading at all with the fluke. I read here (below link) that if you unplug the wiring to the sensor and bridge the connection it will give the ecu a false reading. I did this and the car fired up. I have a new sensor on the way but I also have some new and exciting jobs to do. The right side valve cover is leaking oil pretty badly. I had to laugh, I know there’s a fair bit to keep me occupied under there now. Will update as I go and thanks again
https://jaguarfuelinjectorservice.com/Testing%20Testing%20the%20Jaguar%20Coolant%20Temperature%20Sensor.htm
