In reply to a message from ChinaTom sent Sat 6 Jan 2007:
Tom,
Not sure what the problem could be, but if you’ve fitted the
same '93 model radio as original, this is the wiring set up
for the plug on the back.
Speaker Connections � �93 / �94 cars
All pin numbers refer to connecter LB36 at the radio.
#7 � Slate/pink - RH front speaker + RH front tweeter
#8 � Slate/orange � RH front speaker + RH front tweeter
#14 � Pink/green � RH rear speaker + RH rear tweeter
#13 � Black/white � RH rear speaker + RH rear tweeter
#6 � Pink/purple � LH rear speaker + LH rear tweeter
#5 � Black/slate � LH rear speaker + LH rear tweeter
#1 � Slate/purple � LH front speaker + LH front tweeter
#2 � Slate/red � LH front speaker + LH front tweeter
Other connections on LB36:-
#4 � Light Green/black � Aerial motor
#9 � Purple/orange � Radio Telephone
#10 � Light Green/orange � 10 Amp fused supply - Radio Relay
#11 � Brown/red � 1 Amp fused supply (radio illumination ??)
#12 � Red/light green � to centre console (purpose unknown!)–
I have fitted a replacement radio, and this has half solved the
problem. I now have power to it, and I input the code and the radio
behaves normally. However, I am not getting the right sound. The
rear door speakers put out a very muffled bassy sound, but the
front door speakers and rear tweeters are silent. The leccy aerial
functions properly, and the CD changer works fine. Before I rip the
doors apart the do a continuity test on the speakers, I will just
ask the forum whether this is something I have done incorrectly, or
may it be due to the coincidental failure of all speakers; or is
there a problem with the output from the radio?
Bryan N, '91 Sovereign 4.0 L, (RHD)
Cambridge, United Kingdom
