For what it is worth, I wish to correct an oversimplification in the
discussion on boring the 3.4.
If the objective is to improve acceleration from rest with no regard for top
speed, then you might just want to change the diff ratio. (The force that
accelerates the car is the torque at the wheel.) Given the difficulty of
achieving anything over the speed limit these days, this might well be a
good option, but it will not likely aid your fuel economy.
The objective of maximum acceleration is not simply achieved by maximising
engine torque; rather by maximising the area under the torque curve, between
the usable rpm (shift points). That is, you want more torque for more of the
time, or to say it another way, you need to maximise the useful power. This
might result in quite a different target if you have a 3 speed auto or 4, 5
or 6 speed manual fitted. (You actually want to shift on either side of the
max power)
Ironically, an engine that is popularly described as “being very torquey”
will most likely have a wide power band, which allows lazy shifting, because
you have a fatter power curve between shift points.
An engine that produces more torque at lower revs will win the day only if
the driver shifts at those low revs … which may well often happen driving
around town, but will likely be less effective during “spirited driving” on
a back country road or race track.
If we accept that “the big valve 4.2 S3 straight port head makes more power
everywhere, even on the smaller engines”, then some analysis would show that
this would also produce better acceleration, even on the smaller bore block.
Mark-----Original Message-----
If you are talking about improving the from-rest acceleration,
but not necessarily the top speed, of a heavy saloon, and are
restricted to naturally aspirated induction, then the objective
is maximum torque, not increased RPM and gross horsepower …
My experience and testing show that the big valve 4.2 S3 straight port head
makes more power everywhere, even on the smaller engines, than the ‘‘B’’
Type head.
//please trim quoted text to context only
