Hello folks, I bought a ‘project’ XK140 a few years ago. I rebuilt
the engine & did lots of other mechanical repairs, including
rebuilding the braking system. I rebuilt master & wheel cylinders,
and replaced all the rubber hoses. Finally, I took my long-awaited
first drive, and here’s what happened. A few miles from home, the
brake pedal got extra firm. I could tell the front brakes were
beginning to bind up. The brake pedal was rock solid, so I turned
around and just barely made it home. I jacked up the front of the
car in my garage, and both wheels were locked tight. Also, the
drums were VERY hot. I turned the bleed screw, and hot brake fluid
sprayed out under pressure. Once the pressure was released, the
front wheels turned freely again.
I’ve gone through and rebuilt the master and front wheel cylinders
again since then, just to make sure it wasn’t something obvious.
Still, I always get the same result.
I thought maybe the adjuster bar was racheting the brakes too
tightly, so I removed the rachet springs trying to isolate the
problem. In other words, the brake shoes were free to expand and
retract all the way. Upon testing, I still had the same problem.
Today I’m studying my shop manual, and it occurs to me that I’ve
got a mismatch. The master cylinder is the ‘early Lockheed’ type
(single cylinder). The front and rear brake assemblies are
the ‘later Lockheed’ type (which normally runs off a twin-outlet
master cylinder). The mounting is pretty interchangeable for the
two different masters, so I figure someone along the last 47 years
swapped the two.
Do you think this would cause the brakes to lock up? Personally, I
think there’s something wrong with the ‘rubber cup © in the metal
body (B) that assembles on the larger end of the return spring
(D).’ This is a little valve that sits just behind where the banjo
union is attached. What is its purpose? I followed the (unlabelled)
diagram, and I’m sure it’s assembled properly.
I know the concept is that the master cylinder pushes the fluid
into the wheel cylinders, and the stiff brake springs push the
fluid back into the master cylinder. I don’t know what that little
valve does, do you?
Has anyone experienced (or fixed) a similar problem? I guess I
could buy a new master cylinder, but then I haven’t really learned
anything. Any advice or comments would be greatly appreciated.
Dave–
Dave Shaw
Orange/CA, United States
