John,
We need to agree on what constitutes “Left-Hand-Side”, given discussion last
night at a local Jaguar Club dinner attributed to our new local dealer and a
club member.
Left-Hand-Side is for a RHD car - the front-passenger side of the car (or so
there is no confusion, the Exhaust Manifold side of the XK engine)
If your Sump-Plug is on front/left-hand-side I have no idea what it is from.
If your Sump-Plug is on front/ right-hand-side then that is correct position
for an XK150 Sump.
Roger
Roger Payne - XK140MC OTS; E-Type 4.2 S.1 OTS; DSV8.
Canberra.-----Original Message-----
From: owner-xk@jag-lovers.org [mailto:owner-xk@jag-lovers.org] On Behalf Of
john ledbrook
Sent: Friday, 27 February 2009 12:23 PM
To: xk@jag-lovers.org
Subject: RE: [xk] SUMP HELP and SUMP SHIELD
Hi Roger, so that we are talking about the same thing I am looking at the
car and the sump plug is front left hand corner. The sump has been on the
car since '69, don’t know if it had been changed prior to that. Mounting
points for the sump guard are probably the same as 140, only guessing now.
Regards, John. 825127
Roger Payne
Sent: Friday, 27 February 2009 11:56 AM
John,
Not sure re XK150, can’t say I have ever noticed/recorded an XK150 sump
guard; XK140 ones are rare enough.
XK140 Sump Guard is part number C.8441 and is secured to underside of
chassis frame by 3x3 Set-screws, and this works well enough with XK140 Sump,
where oil-drain plug is at right-rear of its deep-pan 12 litre capacity
sump.
XK150 Sump Guard is a new part number C.13078 but I am not aware of what the
difference is from an XK140 one, and illustration in XK150 SPC looks
similar?
XK150 has of course a new smaller-capacity 8 1/2 litre sump, with oil-drain
plug at front right corner of the step at the forward end of the sump, so I
would not have thought a problem, but I note you say your sump-drain-plug is
on front-left side, not right side, so do we have some confusion regarding
XK150 Sumps?
I notice Otto also said his early 1957 XK150 has a sump with drain-plug in
rear/right XK140 position?
Certainly all XK sumps are interchangeable up to a point, thus my earlier
question regarding alloy XK120 sumps originally being fitted, or not, on
early XK140s, but equally I wasn’t aware there was more than the one sump
originally fitted to XK150.
Not sure that you could easily fit an XK140 sump to an XK150, as the XK140
sump does not have the external oil return pipe necessary to match the XK150
oil filter return hose, unless of course you also fitted an XK140
oil-filter.
Are you sure your sump filler-plug is on the LEFT side, and not RIGHT side?
Canberra.
john ledbrook
Sent: Sunday, 22 February 2009 8:30 PM
Hi Roger,
Missing sump guards!! My 150 I assume would not of had one originally, being
sold new in England. With Terry Hilton’s know how I fitted one to my car.
Problems occurred when wishing to change engine oil. The sump plug being at
the front lh side was difficult to access. A socket extension bar could
reach it but oil could then go everywhere. I had made up some hydraulic hose
and screwed into the sump and capped off the other end to use as a drain
point when needed. It sits up on top off the shield out of the way until its
required. Other alternative was to remove the sump guard every time a oil
change was needed-- maybe this is the reason why so many are missing. Nine
bolts to remove and refit would of tried a lot of peoples patience . I have
also seen sumps with the drain plug at the rear rh side. This would have
been handy with a sump guard on, nothing to undo. Were there different sumps
to suit vehicles with sump guards?
Regards, John Ledbrook
Roger Payne
Sent: Sunday, 22 February 2009 6:02 PM
Thanks John,
I am pretty well happy there is no question at all regarding both early and
late XK140 Sumps being Steel, and pretty sure externally they are visually
the same.
It would appear there is a very minor change around the front oil seal,
which allows a larger diameter oil seal to be fitted from G1908 onwards,
along with a similar change in the Timing Cover housing.
The sump gasket halves also change at G1908 onwards, which suggests
accommodating the larger front seal.
What I remain unsure about is if there are any other changes to internal
trays/baffles which could well be the case since G1908 introduced a new
dip-stick and a new oil pump as well.
Clearly down to detail you could only hope to verify with both sumps off the
engine and together in front of you to examine side by side.
But your question about damaged sumps opens up another situation where the
actual fact does not appear to match the theory:
Supposedly Sump Shields were fitted to ALL export XK140s and special order
only for home market (UK) sales.
My experience is that these very heavy steel plate sump shields are in fact
quite rarely found, such that it is really difficult to believe they were
fitted to ALL export XK140, so maybe they were optional for all markets, not
just UK.
Canberra.
khyber
Sent: Sunday, 22 February 2009 4:05 PM
Subject: Re: [xk] SUMP HELP
In reply to a message from Roger Payne sent Mon 9 Feb 2009:
Roger
I checked G1023 yesterday and its pressed steel. The only cavet I would add
is that it is in perfect condition, that is not dents at al! As Im no expert
on how prone XK sumps are to damage this sump may be a later replacement.
Only problem is there is no way to tell?
Another research topic I would love some concrete help on please.
Does anyone have access to an early XK140 engine, Serial Number G.1001
to G.1907, and if so, can they check and advise if SUMP is made of PRESSED
STEEL or is it CAST ALUMINIUM. Unfortunately my extensive photo records
John McM XK 140 DHC 807003, XJ6 SIII
–Posted using Jag-lovers JagFORUM [forums.jag-lovers.org]-- --Support
Jag-lovers - Donate at http://www.jag-lovers.org/donate04.php –
