The third previous restorer/owner of the dead XK120 I’ve been tinkering with off and on for 26+ years didn’t get the boot floor repair quite right. In addition to being a multi-layered steel sandwich it was set 3/8" too high, which was the thickness of body solder I removed today that had been applied as an aesthetic fix. Looked good till you opened the boot lid. The rearmost lip of the panel was cut down a 1/2" or so to allow the boot lid to close. I’ll post pics of the surgery if it interests anyone.
Anyway, I need to know how the boot floor was configured originally to fab the replacement panel. Can any one of you kind, similarly afflicted XK120 restorer/experts point me in the direction of pictures of said panel, top and bottom?
here’s the boot floor cut away. Notice the difference in elevation between the sides of the boot and the fuel tank support, also the crude patch - to be replaced
That pic’s definitely helpful. It appears the re-construction I’ve just removed might be the same as originally put together - a pic of the underside would confirm, but this is how it is as removed:
The triangular stiffener is rearmost and the boot floor panel is spot welded over top of its forward flange. Then there’s a separate flat panel spot welded to the bottom of that triangular stiffener forming a three layer steel sandwich. There’s a rectangular stiffener spot welded to the underside and forward edge of the floor panel, onto which the fuel tank tray is bolted.
Question is, is this the correct original configuration?
I’ve taken the liberty to change the thread title for posterity.
Thanks for the help, gents. Repairs are done. I had the local metal shop make up the four pieces required to construct the spare tire tray and I spot welded it together. A hundred bucks well invested:
