Hello all,
Would appreciate your help. Working on a left-hand-drive 1970 S2 with the Britax ignition switch and it appears that the bezel is up-side-down when mounted into the steering column. A couple of questions:
- Are there both left and right hand versions out there? (Mine looks perfect if it were mounted on the other side of the column).
- If there were both right and left hand versions, Can I disassemble and reorient the bezel somehow. It appears that the one I have has a challenging tapered pin holding it together. I have attempted to drill a bit but concerned about going too deep into the housing.
Any suggestions or words of wisdom appreciated. Thanks much!
