A question I’ve had for a few decades came to mind today while I was fettling bodywork. My 120 features two different front wing configurations. The left wing features a recessed flange into which the headlamp pod has been let and spot welded in place then lead loaded on the topside to cover the seam, appearing like this on the underside:
The wing on the right side is smooth on the underside, lacking the recessed flange, and the headlamp pod is simply positioned on top for spot welding before lead loading. There is no apparent indication that one or the other was replaced at some juncture, but perhaps it was.
Were there two front wing configurations at the factory? Did one supercede the other at some point?
My theory is the left wing is a replacement taken after a fender bender either from an earlier production donor car or old spares stock, and the right wing is factory original. Seems the earlier wing is better built.
My 120 is the same as yours Nick, smooth right and recessed left, but in my case both wings
are fron another 120. The recess is the later feature to facilitate positioning the headlanp pod
and less lead loading. The difference twixt 120 and 140 is< of course< the diameter of the pod
regards the headlamp, 120 @ 8 1/2" and 140 @(i think ) 8 3/4". My recessed wing also has
a recess to accept a headlamp mounting bowl as used on MK7/8/9 and 140/150.
In days of yore If 140 headlamp pods / wings were used on 120s early MK7 headlamp rims
were fitted.
Peter B
So it’s the later wing that features the recess? Now I’m confused, but that’s not altogether unusual. Both pods are the same diameter, however, so it appears both wings are for a 120.
Could it be there was a transition late in XK120 production to the recessed design and this car got one of each?
Transition ;likely methinks. Perhaps a poster with a late prodution 120 ( 54 ) will chip in. In74/5 I obtained a NOS right hand roadster wing from Olham & Crowther ( now defunct )
based in Peterborough UK. They had a quantity of said wings,without headlamp pods or
sidelight housings, in a stack. Memory tells me that no recesses were formed.
The point of my recollection is that perhaps more RH than LH pressings were formed.
Peter B
I guess the wings with the “recessed flange” are either very, very late XK 120’s or even (modified?) XK 140 wings. My April 1954 XK 120 still has the “smooth” version whereas my 1955 XK 140 has the “recessed flange” version.
quite simple all XK120’s had the smooth underside to wing as built by factory.
The XK140 and XK150 had the trench for headlight pod to sit into.
When the XK140 came along replacement mudguards where made as a standard item to also fit XK120 thereby the 120 finish up with the trench on a replacement guard.
Presumably during production of the XK120 guards where made without trench.
I have had a factory NOS mudguard for an XK120 that had the trench it didn’t have the wing vent so presumably covered the early cars as well just can’t remember if it had front brake vent.
This guard was fitted to 660844
I have had a LH factory NOS mudguard for an XK150 that I have mentioned on this forum set up for every early and late version of an XK150
All wonderful information, gents! Thanks. I know this car was involved in a fender bender on the left side but the damage I repaired was in the replacement wing, so it appears there were two accidents in the car’s history - the first took out the original wing and the second damaged the replacement.
Interestingly, while researching the history of the car, my wife - who is an internet sleuth extraordinaire - unearthed a number newspaper articles concerning the first owner, who was a wealthy American heiress. One of the articles gets into her inability to manage her wealth due to a problem with the drink, which perhaps affected her driving abilities. She bought the car new in early 1954 and owned it till her death in 1966, after which it languished in her garage for a few years while people argued over the disposition of her estate. Far as I can determine the last time the car was driven was into that garage so the accident(s) were apparently hers.
She was the granddaughter of a US senator whose surname, Stevenson, was her given middle name: Jane Stevenson Skidmore. An only child. Daddy Skidmore was a wealthy industrialist who left his daughter a large estate and sizeable fortune - when she died in ‘66 Jane was living off an inheritance trust that paid out around $330,000 a year, or about $2.5 million in today’s dollars.
Anyway, thanks to the insights provided by the contributors to this thread, Terry in particular, I now understand better the asymmetry between the two headlamp pods, ruminated over in this thread:
and rather than load up the slimmer headlamp pod in the replacement, trenched, left wing I’ve removed the lead loading on the right pod, broken the spot welds and using contour gauges and a flex rule have worked the pod a quarter inch inward to match. In this pic just taken, the inner flange already rewelded, the outer awaiting final adjustment before welding and lead loading all around. After this final, final fitting of the bonnet and then onto priming and paint prep.
As you remark Paul, great attention to detail by Nick, but…DEAR! OH! DEAR! Nick has ended up
with 140 profile pods not 120, whatever will the purists say !
The pods on my 120 are left “as is” . If /when I arrive at a Jaguar meet I will run a " spot the difference"
comp ( not just headlamp pods ).
Here`s one ! Unitary floor and transmision cover in 1/8" alloy. .
Actually, no. If you peruse the pictures in xkdata you’ll see clear differences even between cars close together in production dates. This later car - 673342 - has slimmer pods,
that was a random sample. There are many with quite narrow pods, almost like stove pipes, and others with quite wide ones. There were variations in wing shapes and pod shapes and the body men had to establish a close fit between the pod flanges and the surface of the wings in order to effect solid spot welds. Some of the pods would need to be pressed down harder than others - those would end up looking wider.
In any event, it’s the trim ring fit that says it all. Mine fit perfectly. They’re both XK120 headlamp pods.
Interesting construction, Peter. Is there an advantage over the plywood floor boards and sheet steel gearbox/driveshaft covers? And what’s the secret compartment on the right side for? The right seat mount is also interesting - an ejector mechanism for troublesome passengers?
Be aware my 120 is RHD Nick. Light weight and a neat fit around the T5 regs floor.
The lowered floor is for the clutch foot, I have fitted a XJS clutch / brake pedal
assembly therefore retaining the clutch pedal length requires the lowered floor.
A plus to this mod is the cluch leg has to elevate less.
The “ejector” is plain XJ seat adjuster, slightly modded, but I have fitted twin rear
machine guns, hence a side exhaust.
As long as the headlamp aperture was positioned correctly I suspect that with the
rest of the pod it was a case of “best fit” explaining variations. The pod sitting on
top of the wing also required more lead loading resuting in a greater radius where
pod meets wing… The advent of the recessed wing of course gave a positive
location for the pod and ,due to the pod flange and wing being at the same level,
less lead resulting in a tighter radius.
With restored cars it depends on the degree of reparation around the pods of course.
Peter B
