This is part 1 of a long writeup of what I did. Part 2 to
follow.
I have a 2000 Model with 180,000 miles.
My transmission was slipping, trouble upshifting into 2nd
and 5th, gradually got worse, eventually generated fault
code P0775 (Pressure Control Solenoid B Malfunction) with
�Gearbox Fault� error message on instrument panel. It would
only shift up with slow acceleration, behaving as if it was
low on fluid, though it was not, and I even tried
overfilling it. Usually it would work ok going through the
J-gate 2-3-4-D.
This is a common problem with Ford Explorer which uses a
similar but not exactly identical trans.
Before getting into internals, first try an adjustment of
the shifter cable in case you are not getting it fully into
D. I did and discovered my rotary switch on the left side of
the trans needed adjustment, wouldn�t start in N but would
in D, but that wasn�t the main problem.
There are two large round covers on the right hand side of
the trans. These are pressure control servos, like pistons
with a straight rod attached, operated by hydraulic pressure
on the outboard side within the covers, which operate
springy band parts inside the trans and open and close fluid
passages when they move in and out of smooth bored holes in
the trans body. The Intermediate Servo is to the rear and
the Overdrive Servo is to the front.
The problem in the Ford 5R55N and other similar versions is
the shaft rod is hard steel moving in soft aluminum with a
bit of side loading on the inboard end, which wears the hole
in the aluminum into an oval, and it loses pressure around
the shaft.
The Ford approved fix is to bore out the hole in the trans
body and install a sleeve, either bronze or steel, and use
the standard servo shaft rod.
Here are some pictures of the servo pistons and oversize
repair bushing sleeves.
http://www.makcotransmissionparts.com/5R55N.html
Also see the exploded view pdf with all the parts, the
servos are parts 902 and 907.
An entrepreneur in Wisconsin has come up with an alternate
idea which he has patented and is marketing on ebay and at
his web site.
He takes the standard servo and cuts o-ring grooves in the
shaft with specially sized o-rings. I installed these servos
and my problem was immediately fixed.
Caution: Ford makes these trannys with several different
diameter servos, and information on exactly which servos are
used in the Jaguar S-Type is difficult to find and not
always accurate, even if you have the serial numbers from
the tag on the outside. Jaguar is not forthcoming with this
information for some reason. Mine was only the second Jaguar
customer order for this vendor, and he sent the wrong ones
the first time, but corrected his mistake promptly. The best
way is to remove your old servos and quote the part numbers
and colored dots on them when placing your order. Then
compare them with the new ones when they arrive.–
XK120 FHC, Mark V saloon, XJ12L Series II, S-Type 3.0
