Apparently the fuel pump on the series 2 XJ12 fuel injection (75 on) is obsolete and the suggested replacement is the XJ6 series 3 fuel pump. Does anyone have experience with this replacement
Thanks
If it is the same one then it is a standard Bosch item and best bought there. Clamp the hoses and then install it. Watch polarity. It’s just a pump.
If it had banjo fittings then look for a pump with such fittings?
Actually, pretty much any fuel pump designed for a 300 hp EFI engine will work. Some have opted for newer turbine pumps.
Second that, David - as Kirbert says; any ‘300 hp’ pump will do. It’s more a matter of fitting and mating the pump and hoses - and the xj6 pump should be a straight fit…?
Frank
xj6 85 Sopv Europe (UK/NZ)
The plural “filters” leads me to ask: More than one? You must be careful not to put too much resistance in that suction line or your fuel pumps will get noisy.
